I always use main concept to convert from vcd svcd to dvd whenever I do this about 20 percent of the time I get sync problems in the second half of the movie (the second disc) I dont use any video joiner as I had more audio sync problems using them than at any other time, I just use tmpg dvd author and set it to play one track after the other. I do notice sometimes when I start to convert some movies that a message comes up saying something about framerate doesn't match and tells me something was disabled, could this be the problem? if so how do I fix it. Any help appreciated.![]()
No need to run your VCD/SVCD files thru MainConcept - VCD can be authored as is with TMPGEnc DVD Author, SVCD has to be prepared using SVCD2DVDMPEG or simply authored with DVD-Lab Pro.
/Mats
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 20:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 7th Aug 2010, 00:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 17:19 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 16:22
