Does anyone know of a good audio extracting program for mac? I'd like to be able to extract the audio to mp3 or wav files.
Thanks!![]()
There are 10 kinds of people. Those that understand binary and ....
Extract from what?
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
if its extract from DVD, you have to go through the whole
grandma process of rip--demux--transform from PCM to AIFF to MP3.
Or you could use the "dirty south" way
(he, he, he)
and just HIJACK it to Mp3 from source
and be done.
http://www.rougeamobea.com -
If from DVD, use YadeX to rip the track, chapter, or movie to streams. When prompted to save the .m2v stream (the video), select cancel. When prompted to save the .ac3 file (the audio), select OK. Convert your .ac3 file to .mp3 with mAC3dec.
Sorry. From dvd.
Thanks!
newbie award?There are 10 kinds of people. Those that understand binary and .... -
You can use Cinematize if you want an all-in-one solution. Otherwise, you can go the freeware method with something like MTR or YadeX to extract the MPEG Program Stream, then demux with something like bbDemux, then decode with something like mAC3dec. You may be able to extract directly to AC3 elementary streams with YadeX to avoid the demux operation.
I believe that using the freeware method gives you only chapter level extraction resolution so you have to edit it down as needed using QuickTime Pro or your favorite audio editing tool. -
How about this neat little program called bd4go http://denisx.dyndns.org/bd4go/ It can convert DVD audio straight from the disc and convert it to aif or wav sound files?
Never actually tried it but heard good things about it
Good Luck
David
Extracting subtitles from a bluray movie on mac
By BIFFtheSTIFF in forum MacReplies: 4Last Post: 15th Jan 2011, 04:18 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
extracting audio and changing it
By usermm in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2008, 14:41 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03 -
Trimming then extracting audio
By chrishallowell in forum EditingReplies: 3Last Post: 2nd Nov 2007, 00:29
