Allright, don't yell. I amy not even have a clue what I'm talking about here, but what I want to do is take a short looped dv or mov file (mac) and convert it to one of those gf animated files to be used on the web. Is there a way to do this? Or am I even more confused than I was when I first woke up this morning?![]()
There are 10 kinds of people. Those that understand binary and ....
Here is how I would approach this situation. If the video is a quicktime .MOV file I would use mov2avi to convert it to a AVI file. The I would use virtualdub to select all or part of the video that I want to use and then save it as a sequence of bitmap images. Then I would use a program like Paint Shop Pro to convert the bitmaps to gif images. Now remember, gifs allows only 256 colors, so the images might look like crap. Then from there I would use a gif animation tool such as Animagic Gif to create the animated gif file. Thats how I would approach this problem. Good Luck! Scotto
Most Gif animation programs will do this. Just import the video and export as gif.
Here's one that will: http://www.ulead.com/ga/runme.htm
Personally I would use flash instead of gif for web animations perticularly if they are going to long. -
thanks.
There are 10 kinds of people. Those that understand binary and .... -
If the DV has an AVI extension, open it in Adobe Image Ready 7. Edit if desired ...save out as animated GIF
That's what I used for this and many other animations I use here. I captured from the desktop in Camstudio first:
Total newbie needs help urgently (AVDHC -> DVD, with complications)!
By sebkni in forum Newbie / General discussionsReplies: 0Last Post: 17th May 2010, 13:11 -
Total Newbie- Need help Premiere Elements 4- Two cameras Rendering
By VitalExpressions in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2010, 21:53 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 11:28 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 12:24 -
How to convert my dv-ntsc to gif
By drewdude92 in forum MacReplies: 3Last Post: 23rd Jul 2007, 18:59
