Hi,
I am new to DVD copy. I am using DVD Shrink 3.2. I was following as this site explain
http://www.dvd-guides.com/content/view/16/59/
but when I come to Quality Setting two checkboxes are disabled. I can select/change those.
If anyone can explain to me why please...
Sandip![]()
Is the disc you are copying a dual layer disc???
If it is not (if it is a single layer disc), then that is your most obvious answer. -
Thanks Steve for your prompt reply. I did not know that, that Quality Settings is only for Dual Layer disk. So, for single layer disk I cannot use Quality Settings right?
Sandip
No. There is no need. If your source is < 4.377GB (which it must be if it's on a single layer disc), then your compression will be at 100% (ie. not being shrunk). If there's no shrinking to do, then there's no need for the quality settings because all it's doing is ripping the files.Originally Posted by sandipdas
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
