Hello:
I read Sefy's guide and it's very easy to understand however I do have a problem. When I start the program I get a message "no ASPI adapter available." When i ignore this and continue with the process it is VERY slow. Any ideas? Any help?
Thanks,
Bryan
Email me ,and i'll send you a program that will install an ASPI Layer on your PC
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
im sorry Baldrick if you think this is a bad thing just private message me and ill take off the post.....just download ForceASPI 1.7 and it will insatll the lastest ASPI layer on your PC even if you dont have the minium requrments to install the ASPI layer
Unfortunatly ForceASPI is illegal, and even the author was forced to take it off because Adaptec told him to, it does however fix the ASPI Layer issue for most people, and atleast enables them to install the update from the official ASPI.
Best Regards,
Sefy Levy,
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26
