  1. I need to put 2 full DVD movie to 1 dvdr with original menu (subtitle & everything) and create a new main menu to select the 2 full DVD movie
  2. the app that will do this for you is dvdremake pro.
    Is this software stupid-friendly (couple clicks) or does it require some work?
  4. for this feature (merging) very user friendly (practically a 1 click operation) and if you dont mind using it's default menu (menu used to select either dvd). However, you can change it and add your own menu, kind of easy enough for most of us, but maybe a little more complex if just getting started.
    Their is a guide on this site (well linked) that was put up a short time ago that explains how to use the merge feature and use your own default menu if you want to Even some of the other features are pretty easy to use as well.
    here is the link for the guide
    http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php
    I wanted this years ago. Figures it comes out after I made room for more DVDs and blank media got cheap. I may do it, just to say I did it. Thanks.
  6. you know whats funny is that i was waiting years as well and never understood why anyone did not jump on something like this sooner. Well either way it makes me want to re-do some backups where i combined extras from one side whith the film on the other using ifoedit and vobedit. And usually in those cases it works, but not truly like it should be.
    Put it this way, you can do a lot with this app that you cannot do without re-authoring the entire dvd, so to me it was easily worth the money, but damn wish it came along sooner.
