I've installed a couple apps successfully:
-dvd shrink
- dvd decryptor
I would like to install several more, including GUI for DVD Author and Slide Show Movie Maker. I was able to install GUI for DVD Author, but after I installed it whenever I tried to run it it would just freeze up. SSMM just comes with a zip file, I can extract and run it, and all the features seem to work but I get an error when I try to set the output video codec. Is there a way around this?
Also, does anyone have a link to Windows Movie Maker 1?
Thanks,
Garibaldi
Results 1 to 1 of 1
Powerpoint won't run in Wine
By Webster in forum LinuxReplies: 2Last Post: 25th May 2011, 04:17 -
meGUI on Ubuntu Desktop Server using Wine.
By th3obr0 in forum LinuxReplies: 11Last Post: 26th Apr 2009, 09:48 -
[SOLVED] Problems running dvdrebuilder in wine
By freebird73717 in forum LinuxReplies: 3Last Post: 10th Mar 2008, 12:44 -
openSUSE 10.3 Linux, Wine & DVDFabPlatinum [SUCCESS!!]
By burpnrun in forum LinuxReplies: 3Last Post: 11th Jan 2008, 13:45 -
possible to upgrade DVD writer firmware in Linux (e.g. using wine?)
By t35t0r in forum LinuxReplies: 3Last Post: 30th Oct 2007, 13:35
