    Jan 2004
    Seattle
    Hello all, I am having a strange problem that I cant figure out.
    I captured a bunch of video from VHS, brought them into Premiere, edited them and exported a movie. The final exported movie was a 7 hour 7 gig AVI. I tested it and everything was fine (audio was snyched, etc).
    I wanted to burn it to DVD so I used virtualdub to cut it into 3 pieces. The problem is, the 3 seperate videos have no audio. It doesnt make any sense to me why that would happen if the original files audio was flawless. Any ideas? Thanks much.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    In virtualdub, I'd say you had audio set to No Audio.
    If in doubt, Google it.
    Jan 2004
    Seattle
    lol, no thats not it. I always use the settings from this tutorial I did a long time ago (http://www.dvd-guides.com/content/view/13/59/). Ive cut up countless AVIs and never experienced this.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    When you go to cut the AVI up into smaller pieces, can you save each file's audio out to a WAV file ?
