Hello all, I havent posted here in a very long time, and Im just wondering if I can get some reccomendation on what good simple software there is out there that I can use to make tracks on a video before it has been burned. Basically so I can skip from scene to scene on my DVD player.
I can't think of a simple one for adding chapters after it has been authored. IFO Edit can probably do it, and maybe a couple of other low level tools.
Tye simple tools will require you to reauthor to some degree. If the disk is just the movie, DVD Lab can load up the vobs (it will ask to demux - I would say yes to this), allow you to add chapters, then author it out again. Tmpgenc DVD author will allow you to something very similar.Read my blog here.
IFOEdit can definitely do it ... for free. this post might be of some help.
Any decent authoring package can do it though - it depends on how complex you want to do it, whether there will be other titles on the DVD, whether you want menus, etc etc etc. as to which authoring software will be THE best.If in doubt, Google it. -
Sorry it took so long to get back, but instead of putting up a new post, Im going to use this one.
Im going to try the IFOedit as soon as my video is encoded, but I have a question. Since I do this from time to time, the first I have ever started with was creating AVI to VCD using this guide https://www.videohelp.com/divxtovcd.htm which I am still using to author movies. Is there a better way? or better to create DVD instead of VCD?
Thank You
Oh..I should mention that Im using a regular CD-R/RW drive and not a DVD burner. -
Originally Posted by Silver_Ice
Originally Posted by Silver_IceIf in doubt, Google it. -
ok thats cool then, just thought there was a way to burn a DVD using a regular burner.
Originally Posted by Silver_Ice"Art is making something out of nothing and selling it." - Frank Zappa
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
