Is it possible to record from a tv/vcr combo to an external DVD recorder?? If so...can you please tell me now to do so?
Yep, look for either AV Out (aka Video Out) or RF Out on the back of the TV - if it's less than about 5 years old it will probably have both - and then hook that up the the inputs on your DVD Recorder. I would strongly suggest you RTFM for the TV/VCR unit and your DVD Recorder, as they should tell you exactly how to hook it all up.
If in doubt, Google it.
DVD/VCR Combo Player
By pepegot1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2008, 12:41 -
VCR/DVD combo with RF output?
By tac7 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th Jan 2008, 12:17 -
Help deciding for VCR/DVD combo
By UltW in forum Newbie / General discussionsReplies: 7Last Post: 2nd Oct 2007, 22:45 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02 -
Magnavox combo DVD/VCR/TV
By DSedon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jul 2007, 12:36
