hi all!
sorry, im having trouble again O_o i finally figured out how 2 convert mkv to dvd, by using mkvextractgui to extract the audio n subs, but then when i used it to extract the video, it always seemed to go faster at sum parts, n ended up being shorter than the actual movie was supposed 2 be. the result? out of sync audio and video
so what i did was use virtualdubmod to extract the video only, and boom, it worked perfectly!
however, now im trying a different file, a longer one, and for some reason, when i load it into virtualdubmod, i get the error
"An out-of-bounds memory access (access violation) occurred in module 'VirtualDubMod'."
Is there another program i can use to extract my video properly? I can't seem to find one >.<
Thank you!
Results 1 to 1 of 1
[MKV] Need help extracting H264 video from an MKV into an editable medium
By SinanDira in forum Video ConversionReplies: 2Last Post: 12th Sep 2011, 11:44 -
video gets shortened under dvd --> mp4 conversion
By gherardo in forum Video ConversionReplies: 7Last Post: 16th Dec 2010, 17:09 -
MKV to M2TS Video length shortened.
By maven in forum Video ConversionReplies: 2Last Post: 26th Jun 2010, 14:49 -
.mov to .flv - Sync issue and shortened video.
By dillingham in forum ffmpegX general discussionReplies: 1Last Post: 4th Jun 2008, 16:15 -
Extracting H264 Video from MKV Container...
By Dreakon in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2007, 00:05
