Looking for some info on combined VHS/DVD recorders that can be bought in the UK.
Need something that will take my retail vhs copies and back up onto a dvd disk preferably -r format as thats what i like to use, as my main player will only play -r.
Price range looking at say upto £300, but would prefer to spend a lot less....
Not bothered by small problems...
Spend a night alone with a mosquito -
Bush DVRHS01(-RW/VHS-now discontinued) in Argos £199 (maybe substituted with DVRHS02 +RW/VHS)
Daewoo DF4150P at Comet
http://www.comet.co.uk/comet/html/cache/130_232840.html -
Originally Posted by hech54
DITTO
You'd probably be happy buying an inexpensive single layer dvd burner and a tv capture card for your pc. Then hook up your existing vcr to the computer.
I love my hauppauge wintv pvr250. It makes great dvds when I author the mpeg file for burning
I see where you anti combo guys are comming from but i want a standalone solution not something that will tie my PC down for long periods of time. Even at night its fairly active.
This is why a combo would suit me or even a standalone dvd recorder and seperate vhs player.
The 2 combo's mentioned, do they need hacking in anyway to remove macrovision ?Not bothered by small problems...
vhs cassette not sitting down one side in vhs recorder ?
By oldfellow in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2012, 15:23 -
Best VHS/DVD recorder?
By Michael 77 in forum Newbie / General discussionsReplies: 21Last Post: 10th Jun 2011, 17:59 -
Buying a Blu-Ray PC based recorder
By Zetti in forum MediaReplies: 12Last Post: 5th Apr 2010, 19:31 -
USB VHS to DVD recorder?
By 654321 in forum Capturing and VCRReplies: 10Last Post: 29th Jul 2009, 15:08 -
Best DVD-Recorder/VHS Combo For The $$$???
By expat in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Dec 2007, 09:00
