When I had WKS 1, I had a template called CIF that came with the program, that allowed me to burn DVDs using 352x240, 29.97, and 44100 Hz stereo sound. In WKS 2 there is no such template and when I tried to create one the audio option was grayed out - could not be changed and all I can use is 48KHz. I can create such a template in the VCD section of the program.
I know that the standard I am using is for VCDs, but is there a way of making this template in WKS 2 for burning 6 hrs of DVD clips? I find the quality to be adequate for my purposes and all I am trying to do is cram as much video onto the disc as I can. There seems to be a 100 meg difference in the disk capacity. When I use 44.1KHz I have 4.2 gigs of space available. With 48KHz, there seems to be only 4.1 gigs of space available
Thank you.
cai
DVD is not 44.1kHz
It is 48 and only 48.
I think you're going about this all wrong.
Redo audio to 192k 48kHz AC3 in Besweet.
That's quite small. 60MB/hourWant my help? Ask here! (not via PM!)
Thank you lordsmurf, you are correct. Upon further checking of the CIF parameters I noticed that it says 48KHz. I guess my confusion centered on the fact that I have been using TMPGenc to convert to 352x240, 44.1KHz and I have been burning those files successfully, using the CIF setting. I can redo the audio to 48KHz with TMPGenc and everything will be OK. Again, I am not too concerned about the quality of the output.
cai
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 23:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
