I want to get a cable that has RCA component (Y PR PB red, green, blue) on one side and on the other side of the same cable a BNC connection. All I've seen being sold are vga to vga, BNC to vga, component to vga, component to component, etc... Is it possible to get this cable connection by using female to male or BNC to RCA component connectors to make the cable? I want to use this cable for High definition, and want to connect from my HD cable box to computer monitor. I don't know if the signal will go through to my monitor, but I still wanna try. I ALSO currently have a RCA component to HD-15 VGA cable that I can try it with, I use this cable from HD box to HD Television since I have the Y PR PB connection of the TV being used by the DVD player for progressive scan.
Thanks.
Danny
this is a pretty common cable acually , or just use rca to bnc convertors ..
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=587154"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Same cable for BNC, SDI and Composite?
By kayut in forum Off topicReplies: 2Last Post: 31st Oct 2011, 10:37 -
DVR card BNC Female to regular cable (rg60) conversion
By johnnyfly123 in forum Capturing and VCRReplies: 1Last Post: 27th Mar 2010, 16:49 -
Component cable
By alintatoc in forum Off topicReplies: 3Last Post: 23rd Jan 2010, 10:20 -
need advice on cable for pc - tv connection
By mr-scarface in forum DVB / IPTVReplies: 5Last Post: 20th Sep 2008, 21:13 -
Closed captions via a component connection
By bighill57 in forum SubtitleReplies: 21Last Post: 4th Sep 2007, 11:41
