Hi people,
I've been using the videohelp tutorials and forums for about a year now. And i've never felt the need to post because everthing I wanted/needed to know was readily available somewhere on the site/forum.
I'll try to make this as short and sweet as possible. Thank you in advance.
I use TMPGenc plus to convert my video content to Vcd and Svcd. Most of my knowledge comes from the excellent guides on this site. Although i've read guides on here concerning Interlacing/Deinterlacing. I only really half understand it - The same goes for Inverse Telecine & 3:2 Pulldown.
TMPGenc has options to define wether or not the source video is Interlaced or Deinterlaced. Based on my Decision (I think) I then have to choose field order. Can someone please elaborate or perhaps point me to a Guide On how i can determine wether or not the Source im converting from is Interlaced or Deinterlaced??
The same goes for Inverse Telecine & 3:2 Pulldown. When i use the TMPGenc wizard - It sometimes Ticks the Inverse Telecine Filter on some video sources. Yet if i load the same source Manually (Without the wizard) The option is Ticked. So I guess Im asking if there is a Technique Used to determine If the Inverse telecine proccess Is required in any given Video source??
The reason I want to know Is because the Inverse Telecine Proccess can take hours. If this step isnt needed, It would save alot of time. Also, I feel that in this stage of my Video Converting/Editing Hobby, I should know these things - So its a quest for knowledge/convenience
Thanks to all who help and if this is in the wrong Forum section, Forgive me and Plz tell me how to get it in to the correct section.
k_@yne
Quoting myself :
"Yet if i load the same source Manually (Without the wizard) The option is Ticked." I Meant to say :
Yet if i load the same source Manually (Without the wizard) The option is NOT Ticked.
Sorry. -
Thanks Junkmalle. The Two Links You Posted Were Exccellent. Had'nt Read Them Before And They Shed Alot of Light On The Subjects In Question.
Anyone Looking To Understand Just What (De)Interlacing And Inverse Telecine Are .. Read Those Two Links Above.
Thank You Again Junkmalle. -
GSPOT v2.51 or higher detects I/L (interlace) or PRPG (progressive) and tells you TFF (top field first) or BFF (bottom field first) or pulldown (3:2).
IVTC is converting 29.97 back to it's 23.976 roots. This only works if the source cooperates and was originally film at some point in time. The 23.976 is progressive only, so deinterlacing will occur on interlace materials. Overall, a bad idea here, leave it 29.97 and interlaced. The best IVTC is for progressive sources.
This is about as simple an explanation as possible for interlace and deinterlacing:
http://www.digitalfaq.com/capture/interlace.htmWant my help? Ask here! (not via PM!)
(How to) Inverse Telecine
By Cherbette in forum RestorationReplies: 16Last Post: 17th Nov 2011, 14:24 -
Inverse Telecine Anime (Death Note)
By Corpsecreate in forum Video ConversionReplies: 16Last Post: 7th Oct 2011, 03:55 -
Frasier DVD to iPod Inverse Telecine Help
By jmsajdak in forum DVD RippingReplies: 1Last Post: 4th Sep 2008, 10:16 -
PAL Inverse Telecine?
By Anakin in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:34 -
Inverse Telecine, IVTC
By kitty in forum GlossaryReplies: 1Last Post: 10th Jan 2008, 22:40
