Good Morning All
Yes, I'm still using my ULead software until I can find something better
Anyway, I finally got it working (with some help from the forum) but now I have a new problem, I can only capture in SVCD mode (352x240). If I try anything higher I get one of two error messages:
Unexpected Error, The file may be corrupt. Do you want to delete the file?
or
Capturing failed. the file created is corrupted and unuseable, it will be auotomatically deleted.
Plus when I capture in vcd mode, the sound has a lot of feedback on it.
Any suggestions? Or if you know a better program that I can use then I'm all ears since I've been struggling with this one for months now.
I have a pentium 4 2.4ghz computer with 1gb of ram and I have 20gb of free space on my hard drive plus a 20gb secondary hard drive. I'm capturing with and Aver DVD EZ maker capture card and I'm using an S-Video cable to capture.
