codec codec codec , your prob right but i cant get this thing to work at the mo
avi file > tmpgenc express > no audio when playback
checked the avi with avi codec > eaccess violation?
checked with gspot > all seems ok ?
get the inproper vbr at load with vdub
tried to demux with vdub > get broken playback when re-muxed
loads in nan dub with no errors
tried to save as avi using direct stream for vid and aud in nandub , still no audio on new saved avi in tmpgenc express
used avfree codec vt and it played ok in the preview player
my other players play it ok
just cant get sound in tmpgenc express
and have uninstalled and re-installed my codec with a fresh one
the codec in question is MPEG-1 Layer 3 i have 4 codecs installed that will play the file , frauhoffer , creative , lame mp3 0.8.0 3.92 , mpeg layer 3 decoder
any one got any thoughts please
Results 1 to 17 of 17
TMPGEnc doesn't like VBR audio. Demux it and feed it the individual streams. Rip the audio in VirtualDub - save it as a WAV and feed that to TMPGEnc instead.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
cheers m8
but as i said
quote
i agree on what you say and tried -
You do not demux.
You set audio for full processing and save the audio as a wave file. -
Scan it for bad frames maybe? <shrug>
Where did you get this file? Is it something you downloaded? Good luck with it if that's the case
oops sorry guys my terminology slip up
tried saving audio seperate as wav and get broken playback and out of sync issues when re-joined back in with express
i`m looking at uninstalling the lame codec at the mo and changing to 3.69
maybe that will do it ? -
What do you mean by "broken playback"? Is it just lagging on your system with the video or is it actually missing sections of audio? How does the WAV file itself play?
ok back again after a reboot
doh and double doh that didnt fix it still no audio in tmpgenc
ok i loaded the file into vub and got the inproper vbr warning it asked to re-write header or something like that i said no , i then saved the audio as a wav and the only mode i can see is under video there are no mode options under audio , so i saved the file as a wav , streams>stream list , save as wav
then loaded it in express with the orig vid file and playback was there but had short broken bits in it and went out of sync further down the file ? -
First things first...Originally Posted by gilbates
In virtual dub, you need to select audio full processing mode.
You can also check to see if audio is 44,100hz and it is set to stereo.
You then save the audio as a wav in virtualdub. You should also scan for bad frames.
You then load both the original video +the wav you just saved into tmpg. -
Let it fix the header and then save the WAV and see how that goes.
hmmm
ok im using vdubmod 1.5.10.1 and there is definatley no audio option at the top , i got , file , edit , video . streams , options , tools , help but no audio option ?
am i missing something here ?
wo wo hang on right click the stream in stream list and direct stream copy is selected , its ok i`m a bit slow -
Use virtualdub 1.5.10Originally Posted by gilbates
http://prdownloads.sourceforge.net/virtualdub/VirtualDub-1.5.10.zip?use_mirror=internap -
ok i`m doing a full processing mode wav save now , give me a sec and i`l see if that helps
almost
24 mins in the audio just drops out the orig file has it for sure
so i have 24 mins of no popping and synced audio but then , nothing
oh it never rains but it pours
any more thoughts guys -
Where did you get the source file?
If you downloaded it, then you need to get a different copy.
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
AutoMKV Stuck While Encoding Audio
By bobandrews in forum Video ConversionReplies: 2Last Post: 15th Feb 2011, 22:43 -
Audio help needed please
By BrainH in forum ComputerReplies: 1Last Post: 27th Jul 2010, 18:46 -
Audio Encoding Help needed for VirualDub
By Qasim in forum AudioReplies: 8Last Post: 30th Apr 2010, 09:02 -
Audio analysis software needed
By Nelson37 in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2007, 00:17
