when i do my rendering should I leave the computer alone or can I use it to surf or check emails etc ?
thanks
mark
Rendering uses the most of whatever CPU you have available, depending on what you have the priority set to. Doing other things on your PC won't affect it at all. Everything will just be lagging and running slower than hell, and depending on what you are doing you are just adding extra time it takes to finish rendering.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
With an Athlon Thunderbird 900 mhz like you state in your computer profile I wouldn't do too much while rendering on your machine. Hopefully you've upgrade but failed to update your specs.
Handbrake Should i leave it on?
By JackDanielZ in forum Video ConversionReplies: 19Last Post: 18th Sep 2012, 10:13 -
Computer crashes when rendering video
By David Bruno in forum Newbie / General discussionsReplies: 20Last Post: 2nd Feb 2011, 20:33 -
Do you shutdown your computer, leave it on, or put it in standby?
By yoda313 in forum PollsReplies: 21Last Post: 7th Aug 2008, 17:21 -
Bad to leave computer running all the time?
By ryangarfield in forum ComputerReplies: 45Last Post: 14th Mar 2008, 21:31 -
Do you leave your computer on all the time?
By yoda313 in forum PollsReplies: 43Last Post: 19th Sep 2007, 14:09
