I am burning a wedding DVD on Prodisc DVD-Rs. The first test was using PCM audio, which skipped/popped like crazy. I then encoded to .ac3 (I tried with headac3he but got a "could not find data chunk" error, so I used ffmpeggui instead). This eliminated the audio problem when I played it on my DVD player (Toshiba 3690). I sent it home and the DVD worked on two other players but it still had the audio problem on a third player (I don't know which model right now, I will find out tomorrow).
Does anyone know what might be causing the problem? Is it simply too high of a bitrate for some players to handle (it's 7582kbps video + 192kbps audio)?
Oh, and I'm authoring with DVD-lab.
Thanks,
-Brandon
My guess would be it is a player/media compatibility issue. Prodisc is not generally considered as top quality media and therefore can cause playback problems with some players and not others. I would suggest trying a different brand media. Read some of the posts in the media forum to see what is reccomended and what is not. For -R's Taiyo Yuden are considered by many to be the best, but others are well rated too.
Your bitrates are fine and well within DVD specs.
Bitrate Limit for BD9?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2012, 08:56 -
Skipping audio problem!
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 12:02 -
WD TV USB Player 5.1 Audio Skipping
By njsges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jan 2009, 03:31 -
AC-3 bitrate limit on Apple TV?
By InsanelyOne in forum MacReplies: 0Last Post: 8th May 2008, 11:18 -
audio skipping on video capture
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 19:18
