  1. Hello guys,
    I have a new problem....
    I have converted a full serie of Episode (60 of them)
    into .mpgs with TMPGENC now they are 300 megs each
    I don't wanna use Nero vison & only burn 10 episode maximum on 1 Dvd so it will take me 6 Disc to burn the full thing
    what program should i use to put the most Episode on one Dvd at least 4.7 (dvd ) full capacity) I want the DVD-r to be able to be played in my DVD player .
    byt the way each episodes are 30 mins each some 20 / or even 18 mins/
    thanks! & advance again
  2. Member holistic's Avatar
    May 2001
    here & there
    Play time of episodes is not relevent
    You Have :
    60 episodes at ~ 300Mb each
    300 Mb * 12 episodes to a disk for an even 5 DVD set.
    300 Mb @ 30 minutes is a low bitrate.
  3. yes they are low but extremely rare so i have to live with it i thank you i will have to live for 12 a set
  4. Didnt you say you were looking to find a new program to burn with? Or did you find one?
  5. i found a program to burn them....
    by the way i wanted to know does it really matter if i change 25fps to 29.97? so it fits ntsc.?? will it make a Big impact on my files? (because some were pal i think''
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by holistic
    You Have :
    You could almost squeeze 15 episodes to disc (4 discs) and use DVDShrink to pull back down if required. Either that or use DL media and we're talking 25 episodes per disc (2 discs).
    This is all given that you use the MPEGs you have ATM. In an ideal world, you'd work out how many discs you want to use, then calculate the bitrate you need to re-encode at to make this happen, but it'll mean re-encoding all 60 files, so it probably isn't the best option since you've already re-encoded them. We've just gotta band-aid it from here on in I'm afraid
    If in doubt, Google it.
