Will the "16:9 display" setting in TMPGEnc show the widescreen movie properly on TV when I burn the Mpeg2 file?
That file looks taller than the original when I play it on my computer.
I burned an Xvid Ogg file of a widescreen movie with TMPGEnc DVD Author.
The file properties in Windows Media Player says the resolution of the original file is 576 x 304.
When I was encoding it with TMPGEnc I set the size for "16:9 display".
I encoded a 4 second clip just to see if the size matched but the Mpeg2 file was taller.
So I searched on the this site and read about manual centering.
I centered it with made up figures by trial and error until the Mpeg2 file matched the size of the original on my computer screen.
That happened at 853 x 480.
Then I encoded the whole movie at that size and burned it.
It came out wider than the original when I played the DVD on my TV.
Some of the picture is cut off on the left and right sides and the black bars were smaller as a result.
Reglar WMP doesnt handle 16:9 files well sometimes. Open your file in PowerDVD or Media Player Classic instead, as these properly handle the anamorphic flag in the file.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Thanks.
I tried dragging the sample clip into InterVideo WinDVD 4 which is the program that came with my computer.
On the "fullscreen" setting WinDVD 4 displayed the mpeg2 file as widescreen whereas windows media player didn't. -
Originally Posted by kelman3
XviD4PSP Brightness/Contrast setting to reduce PSP "Ghosting"?
By stephens in forum Video ConversionReplies: 0Last Post: 13th Sep 2009, 11:42 -
Setting "top field first" flag without re-encoding/re-authoring
By Miles in forum Authoring (DVD)Replies: 2Last Post: 16th Jan 2009, 06:15 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
Video Setting For Motorola A1200 "Ming" and Rokr E6 Entertainment
By dj4monie in forum Portable VideoReplies: 2Last Post: 6th Jul 2008, 02:20 -
Autodesk Cleaner: adding letterbox black bars ("widescreen matte"
By sybariten in forum Video ConversionReplies: 2Last Post: 13th Mar 2008, 07:57
