Just wondering how good you think this computer is.
CPU: Sempron 2800
MB : A7V8X-X VIA KT400
RAM: 256 MB PC3200 <- will this run at 400 Mhz even though the CPU runs at 333 Mhz FSB or will that slow everything down ?
Results 1 to 11 of 11
It depends on what you plan to do with it.Originally Posted by 888888
My dual boot system has 256MB and I mainly do dvd ripping and burning with it.
If you mainly surf and do word processing and burn dvd's then it is enough. -
My computer's performance felt like it benefited from from being upgraded to 1024 RAM. It seems like Windows responds faster. No proof though, I guess it could all be in my imagination.Originally Posted by bazooka
Memory will throttle down to whatever speed the board/CPU require of it, nothing more. Advantage is you can tighten your latency with faster RAM sometimes. I'd recommend 512MB of RAM, it's the minimum I usually push on folks running XP. With how cheap PC3200 is again it isn't much of a bump in price.
FB-DIMM are the real cause of global warming -
He may not need 512.
It is a value system and will run fine on 256. -
I think later I will give her my 2 256 MB Stick of PC3200 and get myself 2 512 MB sticks so I can run in daul channel mode still but then I will have to sell her 256 MB stick becaus that MB can only have 2 sticks of PC3200 ram in at one time.
Bazooka makes a good point. This is especially true in linux, where the amount of memory you need can vary depending on what window manager you use. XP's Luna tends to be more graphic heavy and therefore slows things down.It depends on what you plan to do with it.
If you can, go for a motherboard that supports DDR400. This will make a CPU upgrade or an overclock easier in the future.
If you are going to run dual-channel memory, don't forget to buy a proper matched pair of modules.
Asus is an excellent choice of motherboard.
Cobra -
Ditto that. My Sony has an Asus MB. I have been a Tyan fan for years, but this P4 MB is impressive
What kind of speaker system is hooked up to your computer?
By johns0 in forum PollsReplies: 29Last Post: 22nd Feb 2012, 04:33 -
Finding a Good Capture Card For An Xbox 360 System?
By LoC Blood Red in forum Capturing and VCRReplies: 14Last Post: 8th Sep 2010, 22:06 -
computer 5.1/7.1 or cheap home system?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 5Last Post: 6th May 2010, 07:51 -
want to use 3 monitors in a computer system
By xinjingqiao in forum Media Center PC / MediaCentersReplies: 3Last Post: 3rd Nov 2008, 14:55 -
how to connect my computer to the LCD TV and to my home theater system
By roise_r in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2008, 07:40
