After playing a copy of Shrek 2 in my Koss KS3120-2 standalone player none of my dvd-r will play.
A message comes up saying "Incompatible disc"
All store bought dvd's will play, the Shrek 2 storebought will play, the Shrek 2 copy will play, but no other dvd-r.
I fixed this problem with a tip from this site (Press Menu, enter 76419 to reset to factory defaults)
I used DVD Decrypter to make an ISO file, mounted it in Daemon tools, burned with DVD shrink(region free).
This is the first time this has occurred, is there a setting I missed somewhere or is DreamWorks messing with me.
Thanks,
Brian
Results 1 to 13 of 13
I saw the same thing happen on a friends toshiba
set-top. We played -r dvd's for a full weekend
problem free. All of a sudden it would only read
factory disks. All recorded disks, which we had
already watched, came up with disk error. The
unit was under warrenty, and promptly returned.
The replacement has been working fine since. I
hope your unit is still warrented.
kiki -
After I reset the player with the remote, all works fine, so I decided to test it.
Store bought and my recorded DVD's play.
Shrek 2 storebought plays and my DVD's play.
Shrek 2 copy plays and then my recorded DVD's will not play.
I'm convinced there is a code in the copy of Shrek 2.
Shrek 2 is a relativly new release so I'm thinking conspiracy,,,,,
Brian -
How long does it take to load? How long did you play the DVD?Did you look to see if there was any other files on the DVD,I dont think there would be..but maybe. Or just the reg VIDEO_TS...
If you really want to test your theory get another copy on a different brand of disc burned on another burner, if possible. I have seen bad pressed discs send some players into oblivion until they could be reset.Originally Posted by Brian1971Still a few bugs in the system...
Canadateck
After my standalone is affected by the Shrek2 copy, my dvd-r"s load at the same speed as factory dvds, but come up as "incompatible disc" as opposed to "play". It appears the Koss player is merely reading some code to say incompatible instead of labouring to try to start the dvd-r.
After pressing play, theS2 copy went through the the following,
Extras (replaced by a single still frame)
Menu board (Play the movie NOW!)
Main Movie in english. (played it for 5 minutes)
Loading the ISO from daemon to dvd shrink only shows the main movie. audio. and extras in the "what to burn" window. so yes there were other files but I don't know what they are. -
Chas0039
Have made 2 copies from original iso, both yield the same results(media is not at fault, must be the ISO) -
Care To enlighten us..Originally Posted by holistic
If anything this does seen strange>?
I would try another brand of media to try and really nail it down to the Shrek2 copy you have.or better if you can get another copy of Shrek2..See where I'm going with this???LOL
Ps: Burn it using another method Maybe. -
I backed up my Shrek 2 - movie only - English only and it plays fine in my player....and so does everything else.
I also made a movie only copy and it hasn't harmed either of my DVD players. JVC & Toshiba.
Also have S2 backup - movie only, english. No ill effects playing in my Sony set top.
Nero Recode on a DVD player set
By Doopopmercury in forum Newbie / General discussionsReplies: 4Last Post: 15th Apr 2012, 21:19 -
Where can I get an older copy of XMedia Recode?
By Djard in forum Video ConversionReplies: 3Last Post: 17th Mar 2012, 15:47 -
Cannot copy finalized DVD-RW from Standalone?
By jaggerdss in forum Newbie / General discussionsReplies: 33Last Post: 28th Mar 2008, 19:33 -
Shrek The Third
By boldego in forum DVD RippingReplies: 3Last Post: 13th Nov 2007, 22:10 -
Is there way to copy a Dvd realtime with RAM drive like a standalone playr?
By Blumphf in forum DVD RippingReplies: 18Last Post: 25th May 2007, 07:21
NO conspiracy.
