Hello to all.
I'm using ULEAD Movie Factory 3 and everything is fine except two things. Most, if not all of my recorded DVD's come up in a screen size which is a bit bigger than the TV screen size for some reason. So when subtitles are involved I usually cant see the bottom line. Is there something I have to do to fix that?
Another problem is that when I burn the DVD's while they are in MPG or AVI fornats it takes forever and sometimes it even freezes after 5 hours of waiting, so I usually have to convert all movies to DVD format with Main Concept, but that programm doesnt cover all video formats like WMV for example.
Any suggestions?
Thx.
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
Any DVD player that will play divx files larger then 2GB?
By David9799 in forum DVD & Blu-ray PlayersReplies: 27Last Post: 9th Nov 2007, 11:53 -
Auto-fit seemingly creating larger DVD's
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 16th Oct 2007, 17:08 -
DVD larger than 4.7GB, is it safe to use "AutoFit" and burn on 4.
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 10th Oct 2007, 15:49 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37
