Hi,
I recently asked Liteon's technical support whether
the US models of the Liteon 5005 and 5045 can record
in both PAL and NTSC (from the video inputs, not the tuner),
and whether they are 110/240 V compatible.
The reply (enclosed below) was that the US models of these two
recorders can record only in NTSC (and their voltage is 110V only)
I am surprised: I thought that the US model of the Liteon 5005 used
to be able to record in both PAL and NTSC (like the Liteon 5001),
and that it accepted 110V/240V.
Did they disable all these features in the latest version of the 5005?
Can anyone with a *recently manufactured* US model Liteon 5005
clarify whether it can still record PAL signals from its video inputs
(S-video or video composite).
Also, is the power supply of recent Liteon 5005's (US model) only
110V or 110/240V?
Thanks!
My e-mail to Liteon (sent on November 23)
I would greatly appreciate your help regarding the
regarding the LITEON 5005 DVD recorder - US model:
1) Can the 5005 (US model) record DVDs in both PAL and NTSC
from the composite video inputs?
2) Is the 5005 power supply 50/60Hz 110-220V?
I am also interested in buying the LITEON 5045 (with the 160Gb hard drive) --
US model, if it is also able to record in both PAL and NTSC:
1) Can the 5045 (US model) record DVDs in both PAL and NTSC
from the compositet video inputs?
2) Is the 5045 power supply 50/60Hz 110-220V?
DCUS_Service@liteonit.com
Hi,
Both units record only on NTSC if you get the in the U.S.
The power supply is AC 100~120V, 60Hz
Thank you for contacting Lite-On Tech Support. If you reply please include all previous emails.
Best Regards,
Philip, Lite-On (USA) Tech Support, http://www.liteonamericas.com
Results 1 to 14 of 14
If you power cord is in a grommet and hard-wired to your unit....he is most likely correct that it has U.S. Current.
If the power cord looks like your printer power cord(it plugs into the back of the unit) he might be wrong. I use that as an indicator for the most part.
My DVD Recorder(U.S. Version) has a printer style power cord.....have I tried it on my new European current?
NOT A CHANCE....
Thanks for the suggestion regarding the power cord type.
Unfortunately, I don't have access to a Lite-on 5005 that I
can check: I want to order one by mail, and I can't find one
to actually see in Ontario...
I am hoping that someone in the US who sees them at Costco
(apparently Kmart also carry them now), can check the back
of this recorder, where the power cord is attached,
and read whether it is rated 110~240V 50/60Hz,
or just 110V, and let us all know
Thanks! -
Can't you do a google image search for the 5005....I'm sure there must be one on there by now that shows the back as well.
How about this:
http://www.dvdplusrw.org/video/leaflets/liteon_lvw5005_2.jpg -
I just purchased the 5005 on Friday (11-26-04)from K-Mart. It was $149 and I paid $16 for a 1 yr replacement warranty from K-Mart. It is a Xmas gift but I did open the box and am reading up on it.
The power cord is separate from the unit. It says manufactured in China in September 2004 on the outside of the box. This is my first dvd recorder purchase and it's for someone who is a little technology challenged so we shall see.
It has on the cord:
7A 125V
LS - 7J
Hope this helps -
Forget the cord.... what is on the sticker that is on the back ?Originally Posted by tryintooPinnacle Studio 8 and DV home video editing (ver.9 already home)
Info from back
Model Name: LVW-5005A
Rating: AC 100-240V 50/60Hz
Power Consumption: 36W
Same as above apparently -
coolOriginally Posted by tryintooPinnacle Studio 8 and DV home video editing (ver.9 already home)
Great news! Thanks a lot for the information tryintoo.Originally Posted by donpedro
I am amazed that the Lite-On service person
wrote to me that the US model Lite-on 5005
works only with 110V!
(see the first posting on this thread).
Given that this person was wrong on the voltage,
and that the voltage is 110/240 (euro-compatible),
I bet that the US 5005 is STILL able to record PAL signals ---
despite the "no" that I got from the Lite-on Service guy...
(but It would be nice to have someone actually double-check this by recording a PAL DVD...
Now the same questions (voltage? PAL/NTSC?)
remain about the US model of the Liteon 5045.
I guess we will have to wait till it is released...
P.S. I have been following this forum for several months,
and I learned a lot from all of you. Thanks a lot for
all these great postings! -
.....and since when have DVD Recorders had tuners that are compatible in both PAL and NTSC?
Is this fairly new as well? -
I am pretty sure that the Lite-On 5005 tuner (US model) is NTSC only.Originally Posted by hech54
The question is whether the 5005 can record PAL signals from its composite and S-video inputs (not the RF coax cable).
I believe that the answer is affirmative...
I am not aware of DVD recorders that have PAL/NTSC tuners,
but that's probably only ignorance on my part.
Off-topic question: is any one aware of the planned release
date of the 5045 in the US? -
Again quote from liteon site...
Would seem to say its either not both. But that will be for when signal is required to go through tuner. Composite might not...TUNER FORMAT Top of Page
Signal UHF/VHF/CATV
System NTSC or PAL/SECAMNot bothered by small problems...
Spend a night alone with a mosquito
Upgrade Liteon lvw-5045 to 400G successfully
By totoro168 in forum DVD & Blu-ray RecordersReplies: 237Last Post: 27th Feb 2023, 17:53 -
Had anyone updated their Liteon 5045 or other standalone to SATA DVD ?
By bithead9 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 29th Nov 2011, 19:31 -
LITEON LVW-5045 cannot read DVD-R disks
By elfie-gow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2011, 17:58 -
Liteon 5045 Hard Drive Recoring Transfer
By allibg5 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 25th Feb 2009, 15:43 -
LiteOn Lvw-5045 (UK - English)
By cubud in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Jun 2007, 15:05
