I would definitely get rid of the stock fan and get a better one.
Results 31 to 44 of 44
Originally Posted by Cobra
Cos thats what im upgrading to after the new year (hopefully prices will fall after the christmas period) -
Originally Posted by FlaystusNothing can stop me now, 'cause I don't care anymore.
Originally Posted by ViRaL1
I don't even have a CPU to use it, though I imgine I will eventually. I just find it odd that we've heard nothing new about it. No firm release date, no new info. No updates on any websites with info obtained from leaked copies. NOTHING.
Its like either for some reason the secuirty on the project is ultra tight, or it ultra sucks so bad nobody has bothered to leak it.
Maybe its a plot by Intel to pay off MS so that an OS to use the Athlon 64 doesn't come out. -
Originally Posted by MACCA350
Are you guys aware that Intel itself has said that their processors are approaching the Watt/density of a nuclear reactor?
ie, the draw over the minimal size of the die, what, 1/6 of a square inch, and 70 or 80 watts to be dissipated. One hot sumbitch. Cooling is getting to be more and more difficult.
Boxed processor is guaranteed to keep the chip cool enough to run, or they will replace under 3 year warranty. Buy a Super Thermotake, instead, stick it in your butt, dummy.
I just burned up a 2400 XP and thought I had the boxed HS, but , No,Volcano Copper. Tough shit.
Cheers,
George -
Intel will warranty other HSF. There's a short list of approved ones, but they support them. At least they do on the server side of things. They don't support them overclocked. Intel chips will still throttle down until it shuts off the computer rather than damage the chip. The old Athlon chips didn't have this feature. Proper cooling will just get you better performance from your CPU, not necessarily keep it safer.
FB-DIMM are the real cause of global warming -
My AMD came from the makers running quite hot... played around with it and noticed that my side case fan was blowing the wrong way. HAH
so i dont get how they can tell what HSF you used in the first place?
or maybe Intel is making M$ support their Pentium 4 64 bit instruction set before XP64 is released... -
Glock,
As far as AMD is concerned, if you have an HSF with a registered SN, not that you went to the site to do so, it is covered under the 3 year "Boxed", aka Processor in a Box, warranty.
Should you have gone to a nitrogen cooling system, so long as it was a PIB, you are covered.
Cheers,
George -
Originally Posted by gmatov
it just makes no sense how they would cover a crappy ass fan but not an all copper with a 80x80 case fan that im runnin. i cool the chip by 10-20 but they wont cover it? oh give me a break
Stream from friend to friend program easy to make?
By Homebrew77 in forum Video Streaming DownloadingReplies: 0Last Post: 30th May 2011, 06:27 -
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 09:53 -
Need best router for multiple pc's....2.4ghz or 5.0ghz?
By neworldman in forum ComputerReplies: 5Last Post: 22nd Nov 2010, 10:36 -
802.11n using 40MHz in 2.4GHz mode
By AuroEdge in forum ComputerReplies: 0Last Post: 7th Nov 2009, 11:07 -
Pentium P4 SL7E2 = Northwood or Prescot ???
By blinky88 in forum ComputerReplies: 6Last Post: 4th Aug 2008, 14:26
