  1. i've tried, nero 6, dvd fab, and dvd decrypter and they don't back up my back up dvds correctly. it gets to a point where the dvd drive can't read certain sectors of the disc. help!
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Defective media maybe? Or scratched/dirty disc? Try it in a different drive.
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    This sticky might be able to help.
    If in doubt, Google it.
  4. as the programs try to read the back-up, they reach certain sectors that they won't read and i keep getting "retry, ignore, abort" options. last program i used was dvd decrypter in iso mode.
    i've played this back up in my dvd player without any problems of it getting read.
  5. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Sounds like your DVD drive isn't up to the task. Find a different drive to try your disc in.
  6. i've used dvd-r's to make all my back-ups since they're more compatible with more dvd drives than +r's yet i don't understand why some dvd players still act funny with the media. is it the brand of the media or the fact that the media is -r instead of +r
  7. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    It's hard to know for sure. Sometimes it's bad dye on the disc.... Other times it is a bad burn (bad buffer?).
    And also it can be that no matter what you do it will not play a +r disc. You just have to keep doing the trial and error thing.
    Kevin
