I just downloaded TDA 1.6 to try out. Creating a single track, I edited a movie that I recorded from TV and cut out the commercials. This automatically created chapters for me. In the Create Menu area, I have my chapters listed. But there are no thumbnails displayed. If I edit a chapter, then a thumbnail is displayed on the Text Settings dialog. According to the help, I am suppose to be able to double click on the thumbnail in order to change it. That does not work. I then created my DVD files and viewed them using PowerDVD. When I clicked on Chapter Menu, I go to my list of chapters but there are no thumbnails. How can I get the thumbnails to display in my chapter menu?
Warren
A thumbnail shows exactly what video is present at it's position. Sometimes it's just black.
To edit anything in Author just click it once. In the case of a thumbnail, click it and a viewer box should pop up with the label "change thumbnail image" use the slider to seek through the video to any frame you'd like to be your thumbnail and hit "Ok".
If that doesn't work, you've got some weird issue because it's a very easy process."Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
I think what is happening is that you only have the tect for the chapter ie. chapter 1, 2 .... but no actual thumbnail display above that ? If so, It's because of the menu theme you've chosen. Go to the Menu area, then select Edit Theme. The top left is where you select what the main menu will contain, and the one below that is for the track menus. I'd say you've got one of the text-only ones selected in here, Change this to one with thumbnails and text, then click on each thumbnail if you want to chagne the image it displays.
If in doubt, Google it. -
Jim,
That was it. Choose a different theme and all is right with the world.
Thanks,Warren
How to create chapter menu without thumbnails
By truongv0ky in forum Authoring (Blu-ray)Replies: 3Last Post: 4th May 2011, 16:05 -
Need one app to trim, crop, menu, chapter and author to DVD... in batch!
By bhershey in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2011, 13:06 -
TMPGEnc DVD Author 3 (Chapter Split In two)
By GeorgeD123 in forum Authoring (DVD)Replies: 2Last Post: 13th May 2010, 21:44 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
Tmpgenc DVD Author 1.6 How Do I Move a Chapter One Page Over
By sneed in forum Authoring (DVD)Replies: 14Last Post: 3rd Nov 2007, 08:47
