I have an XVID AVI that I converted to VCD using TMPENC.. I then burned the VCD compliant .MPG using Nero.
My problem is... my DVD player wont play it. The DVD player plays VCD's fine so it's not that.
What am I doing wrong?
If I put the VCD back in the computer I can play the .DAT file with Windows Media player.
Am I missing a setting? What info can I give you guys to diagnose the problem?
Havok,
Sorry - I know this doesn't address your problem directly, but it might be a practical solution if you can't get Nero to author your VCDs.
Drag your .MPG file that TMPGEnc outputted into VCDEasy, and use that to create the VCD image file. Feed that into Nero (although I prefer CDRWin) and burn it as an image file. It should work no problem.
I say this because I had the same trouble - VCDs authored directly through Nero wouldn't work on one of my two DVD players. No idea why.
Also, use a CD-RW to test the burn so you don't end up with a coaster or two!
Hope this helps,
Cobra
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 04:36 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
My pana s97 and pana ex75 wont play my vcd's correctly
By ozizu in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2008, 22:32 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 20:59 -
*for all who use nero,and dvd wont play in your stand-alone*
By headstate in forum Authoring (DVD)Replies: 182Last Post: 24th Jul 2007, 02:00
