i can get some vcds to work on my APEX AD-500a, but i see them in like 400 blurry 1inch boxes. wtf is this all about?
My DVD player doubles up the VCD resolution to DVD resolution, which means that the blocky bits when stuff moves quickly end up really big and the picture is more blocky aswell because it was doubled up resolution (I don't think it's very good at MPEG1 decoding 'cos it looks a bit worse than the software DVD player plays them on my computer, which also doubles up the resolution)
It could be your DVD player. Unless your files look that horrible, check it out on a computer first, if they look just about as bad then it is the mpeg's.
Other than that, Apex has at least 2 versions of the 500a, a good one (lucky me
) and of course a bad one. There's quite a big difference between the two decoder boards. A family member of mine owns another 500a with different chips than mine, and VCD's that work and look great for me, hardly get reconized in his player. When they do, it's worse than a 10 year old VHS. You can even see *hairy lines* in DVD's. I'm pretty sure it's on par with the 500b models.
If your after great VCD playback, you might want to look into buying a VCD only player, or at least a better DVD player.
Can you rip a dvd without the menu requirement...plz read for nfo.
By darkcyber in forum DVD RippingReplies: 5Last Post: 11th Jul 2011, 23:45 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
MiniDV to DVD - Horrible playback on DVD Player
By tessander in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Feb 2009, 15:02 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 03:09 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28
