Hi
I encoded a stage show captured using my digital camera using Ulead video studio. first i captured in mpg1 VCD then mpg 2 svcd. svcd file was over 701mb in size than vcd. someone told me that in mpg 2 size doesnt matter the length of the clip matters. does this mean even if it is bigger than 701 mb it will fit in a normal cdr.
THe mpg2 size is about 1300 mb.
Results 1 to 12 of 12
If you cdr is only 700mb that is the amount a info it can hold. there is some cdr's that are 800mb..
It's all in the way you burn it. If using Nero, it has templates set up that configure everything for you and will do it just fine. On occasion, you may need to turn off "Create standard compliant CD" to stop Nero from re-encoding. The other option is to author to an image file, which should then burn no worries.
If in doubt, Google it. -
I never really made many Vcd's, Just burnt afew Xivds. But guess its all the same 1300mb is way to much for one cdr.
Size doesnt count if it is an image file? it will just over burn the few exrta mb"s? i know not 1300.but the 95mb extra you say you can get on to it?
You must split or encode with lower bitrate.
Read https://www.videohelp.com/guides.php?guideid=8&howtoselect=1;3#8 . -
VCDs and SVCDs are burned in mode2, allowing for more bytes/sector than regular mode1. You can fit 798MB of VCD/SVCD content on a 700(actually 703) MB cd. (If you use nero to burn regular data cd's there's a setting somewhere asking you if you want to burn in mode1 or 2. When you burn (S)VCD's that tab is greyed out and it'll burn in mode2)
Look up mode2 and mode1 cd burning and you'll find a lot of info abut this. Alternatively look at the (S)VCD specs and you'll see what this is all about.Sorry, I had to go see about a girl -
There's more on mode1 / mode 2 in the FAQ
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05
