Results 1 to 12 of 12
  1. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    I have this problem when encoding a movie from a DVD author 1.5 program file it says this
    dvd shrink encountered an error and cannot continue
    program error -exception occurred not enough storage is available to process this command
    I have used dvd shrink heaps of times and I have 30gb spare on my Hard Drive
    What can be causing this
  2. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    just a update I did it on a different hard drive and still does it
    the error come up after it does the Analysling
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Are your drives set to NTFS or FAT32 ?
    FAT32 has a 2 GB file size limitation that can cause this error.
    Read my blog here.
  4. Originally Posted by guns1inger
    I believe it's 4GB.
  5. Banned
    Sep 2004
    Inner Circle of Thought
    I believe it's 4GB.
    You are correct. It is 4GB
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I believe it's 4GB.
    I'll 3rd that
    If in doubt, Google it.
    Apr 2004
    Miskatonic U
    OK then, 4 GB. If he has 30gb spare and the system is complaining of space issues, this is still the most likely candidate.
    Second on the list would be Norton's protected recycle bin.
    Read my blog here.
    Sep 2003
    That shouldn't be what the problem is. Shrink ceates 1 gig files. I have 98 and have never received this error. Did you change any settings?
    Mar 2004
    Southern California
    Sounds silly but try empty recycle bin if you haven't already. Guns1inger made a good point regarding norton protected recycle bin. 4 gig limit shouldn't be an issue, unless you are trying to output as disc image, and even then I believe windows will automatically break the >4 gig file into 4 gig + remaining gigs.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    "not enough storage is available to process this command" - sounds like a RAM issue ???
    Try rebooting and then try it again.
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Are you using DVD Decryptor to write an ISO image ?
    Read my blog here.
  12. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    I'm running NTFS
    30 gb spare
    I dont have norton installed
    Recycle bin is empty
    I just used DVD clone worked fine
