Hi guys
Can anyone help me..i am having Audio/Video sync problems and was told to try video studio as that is great for sorting this problem out.
i have tryed to follow a guide on doom9.org..but i cant make head or tail of it.
does anyone know how to use this proggy or can direct me to a dummies guide ?
Results 1 to 14 of 14
There are many guide's on the ulead site it self.You may want to try those.
The easiest way to fix sync issues is to make it a non issue. See this thread: https://www.videohelp.com/forum/viewtopic.php?t=166660
thanks both..tryed the guides on the website but nothing about fixing audio/video sync problems.
any more suggestions would be great. -
Well, what sort of synch problems do you have?
Hello. -
Did you see the online manual at Ulead site? It's kind of buried under downloads-documentation. Here is link for vs 8
ftp://ftp.ulead.com/pub/Manual/videostudio8/vstudio8e.zip
and here is link for vs 7
ftp://ftp.ulead.com/pub/Manual/VideoStudio7/vstudio.zip -
Was the MPEG captured from tape? If it was, you'll need a Timebase Corrector (TBC) between the source and your capture device
no, i have a dvd movie and i want to make a back up of it, but after i rip it i get the sync problems.
1. What program and settings did you use to rip the files?
2. Have you processed the files (eg demux, reencode, transcode) before synch problem occurs?
3. Is the original dvd in synch?
4. Does problem occur played back on computer or burned dvd in standalone? (Perhaps synch problem is due to computer's playback software?)
Answers to these question will help the more tech-savvy members here solve your problem.
I usually rip with decryptor in file mode full disc, process through dvdshrink with no compression to remove extras and if shrinking needed go to dvdrebuilder and cce basic. I've had no synch issues and excellent quality.
BTW DVDLab has ability to correct a fixed synch problem (located in tools) but I don't believe it can fix gradual drift.
Best of luck. -
If the audio is behind the video, just use VirtualDub to interleave the audio. If the audio is behind the video by say, 5 seconds than you type in "5000" in the "Delay Audio by (this many) ms". My girlfriend who had practically no experience with audio/video was able to precisely re-sync an out-of-sync DVD Rip by using this method. Cheers.
PS: Ulead VideoStudio is garbage.
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 17:02 -
Ulead Video Studio 9 - colorspace
By Froddy1 in forum EditingReplies: 0Last Post: 2nd Feb 2009, 11:49 -
Ulead Video Studio 11 (to dvd)
By Firesign in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 13:23 -
Ulead Video Studio 10 avi help
By theguy1991 in forum Newbie / General discussionsReplies: 15Last Post: 25th Oct 2007, 16:57 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 12:14
