I have a HIFI system, I understand that it can be connected to my TV and I can successfully play my VCD's on it and watch them on the TV screen.
Any ideas how and what is required.
I have a dvd player on my PC and a Matrox G400 graphic card - would this help my to view the VCD's on my TV ?
If the graphic card has a TV-out, sure. Better you test some different CD-RW on your standalone.
https://www.videohelp.com/phpBB/viewtopic.php?topic=67227&forum=8 -
it doesnt have the TV-out (I think), what it is a 2 VGA type sockets hangingi off the card. maybe I cna get a convertor or something ???
Bad idea. You can get a RF converter, but the picture quality on the TV Sucks, what a waste of money, I know, because I tried it. Best bet is to buy a stand alone DVD player that will play VCD & SVCD & hook that up to your HI FI system. Check the compatibility list. I bought my DVD Player for less than $150 at Best Buys. Save the DVD player in your computer for ripping DVD.
Kully,
The G400 is a 'dual head' card. If you visit the Matrox site, one of there FAQ sections has a pinout diagram for the second output on your card. Part of that is a standard RF out signal.
You should be able to cobble up a TV lead from that. Then you go into the advanced section of your video options and enable dual head DVD-MAX ( I think! I use a DVD player so I don't use the vido out of my G400. )
That should do it.
Have fun,
Ian
Lg dvd player/system not playing dvds
By maddog83 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Feb 2012, 20:14 -
Why does my home theatre system stop playing subtitle after a few minutes?
By fantasyvn in forum SubtitleReplies: 1Last Post: 10th Jan 2010, 05:02 -
VDC Quality website
By saladonyourlincoln in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 06:46 -
'vlc' playing dvd copied to file system
By canellas in forum LinuxReplies: 6Last Post: 2nd Jan 2008, 05:02 -
Trouble playing DVD-Rs on home system
By wysiwyg20 in forum Video ConversionReplies: 1Last Post: 14th Oct 2007, 08:27
