hi,
im trying to rip a film i made off of a dvd i made in iDVD 3. how should i go about doing this?
just an fyi, im on OS X vr. 10.1.5
Results 1 to 9 of 9
:: ehmjay.
I tried to piece together what you're wanting to do from the other thread. I think what you're looking for is MPEGStreamclip which was around last August.
http://www.alfanet.it/squared5/mpegstreamclip.html -
the other topic is actually sorta unrelated. what i need is a way to take a film i burnt using iDVD and rip the film so i can use it in FCP. thanks!
:: ehmjay. -
MPEGStreamclip
If you have Toast 6 you also can drag the VIDEO_TS folder to the Video window (with DVD Video selected) select the title and click Export. This saves the movie in DV format.
Other applications also export to DV such as DVDxDV and the Export2DV in the licensed version of MPEG2 Works. -
mpegstreemclip doesn't seem to work for me. stupid computer.
:: ehmjay. -
It also requires the Apple QuickTime MPEG2 Playback Component ($20). Otherwise, you'll have to use something like DVDxDV if you don't want to buy the MPEG2 decoder from Apple.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
ummm well that might be a slight problem because we only have 10.1.5 and none of the rippers will work.
does anyone have any other alternatives?:: ehmjay.
Video Errors Ripping ..
By donotron in forum Blu-ray RippingReplies: 1Last Post: 7th Dec 2011, 23:45 -
Ripping video from NBC.com
By IgnorantNoob in forum Video Streaming DownloadingReplies: 2Last Post: 7th Sep 2011, 08:05 -
Ripping Video From VBS
By Pacmakaveli in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2010, 14:25 -
idvd and ripping dvds
By gillomax in forum MacReplies: 3Last Post: 29th Sep 2009, 11:22 -
cut Video file by iMovie/iDVD
By cebep in forum MacReplies: 1Last Post: 2nd Dec 2007, 08:19
