Results 1 to 10 of 10
    Jun 2004
    Canada
    hi,
    im trying to rip a film i made off of a dvd i made in iDVD 3. how should i go about doing this?
    just an fyi, im on OS X vr. 10.1.5
    :: ehmjay.
  2. im trying to rip a film i made off of a dvd i made in iDVD 3. how should i go about doing this?
    As far as ripping a dvd in Linux, I would recommend DVD:Rip, I haven't personally used it but have heard alot of good things about it. You can find it and alot of other free linux software at:
    http://freshmeat.net
    Also, do you know how to install from source code? If not let me know and I'll be glad to help.
    Apr 2003
    Depending which distro your using you might not have to compile it. For instance all of these apps are available in rpm form for the Mandrake users. I use vobcopy myself. I use it in my process of going from dvd9 to dvd5.
  4. Depending which distro your using you might not have to compile it. For instance all of these apps are available in rpm form for the Mandrake users. I use vobcopy myself. I use it in my process of going from dvd9 to dvd5.
    right. I was just listing the universal option, obviously you could use:
    apt-get
    slack-get
    slapt-get
    swaret
    portage
    ect
    to install or just tgz, deb, or rpms.
    Apr 2003
    Your correct! Iwould be helpfull when sombody ask for help it would help us to help them if they let us know what distro they using. This way we can save lot of time. Don't forget "urpmi"
  6. Your correct! Iwould be helpfull when sombody ask for help it would help us to help them if they let us know what distro they using. This way we can save lot of time. Don't forget "urpmi"
    Yeah, that would make it alot easier. What distro do you use? I currently use a version of Slackware called topologilinux. I've been hearing alot of good things about debian too, what are the main differences between the two, and do you think its work switching?
    Apr 2003
    I've been using Mandrake for years since Ver 6.5. The Main reason is that it is one the easist to install and maintain. I do about 3 install a month for people who are tired of windows and want to try llinux. With Mandrake so windows like it easier for sombody who's not a computer geek to use and maintain. All of the video apps I use like Avidemux, ffmpeg, gv4l, kino, lve, kavtosvcd, all the dvd authoring tools, the list goes on are precompiled for it. Along with all the codecs for xine & mplayer easily available. All I have to do is just install it just like windows but with the stabilty of Linux.
  8. gv4l, dvd authoring tools
    Do you have some links?
    My reason for liking slackware is first that it is free. Second, its the oldest distro and has a big support group. Also its not bogged down by distro-specific stuff IMO.
    Apr 2003
    gv4l - ftp://ftp.easynet.fr/plf/mandrake/10.1/i586/
    as for the DVD authorig tools:
    klvemkdvd
    http://rpms.mandrakeclub.com/search.php?query=klve&submit=Search+...
    qdvdauthor:
    http://rpms.mandrakeclub.com/search.php?query=qdvd&submit=Search+...
    or simply do a seach at:
    you don't need a club membership to access these sites.
    The first 3 disk of disk of Mandrake are still free. Its only the power packs they selling or if you join the club you get your choice of a DVD iso or the 6cd set of the power packs twice a year included with your membership.
  10. gv4l - ftp://ftp.easynet.fr/plf/mandrake/10.1/i586/
    klvemkdvd
    qdvdauthor:
    Thanks alot for the links! I'm not sure if the mandrake packages will work on my slackware install though- I'll look around for some source.
