ive coverted a few of my films over into divx and copied them to cds using nero.the problem im having is that ive downloaded a few others aswell but tmpeg dosnet recognize them.after looking at the movies there in video clip format or whatever that maybe!!!!
does this mean all i need to do is burn them to a cd without converting them or do i need to convert them???
if its the latter what can i convert them with as tmpeg dosent recognize the format.
and if its the first do i need to put the additional files like the the ones you get on a vcd disk????
please help
ta in advance
lee
Results 1 to 1 of 1
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
Converting Bi-Lingual VCDs to Single Language MPEGs
By HHBear in forum Video ConversionReplies: 3Last Post: 13th Feb 2008, 22:05 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
