i have a problem with some dvds ive recently done, i took the mpegs from 2 svcd's and joined them with avi/mpeg/rm/wmv joiner v4.01, then i ran it thru tmpgenc 3.0 xpress to bring the resolution up to 720x576, next i used tmpgenc dvd author to encode and burn it to a dvd. ver 1.5.15.49
everythings fine except the movie always freezes at the exact spot where the join is.
what do you lot use to join togther ? or where am i going wrong?
Don't join your files. If you want to bump up the resolution do it, but 720x576 may be overkill unless your source is already a higher res. Your call.
Load both mpgs into TMPGEnc DVD Author as part of one track. Author will join the two when the disc is outputted.
I can tell you from many experiences that Author has no problem joining files together as long as they are encoded correctly in the first place. There should be no way to tell where the join is. -
Originally Posted by Matt D
I don't know if anyone else has had this problem, all i can say is i have had it happen everytime!!!
How can I join MPEG-2 files?
By sofakng in forum EditingReplies: 6Last Post: 30th Jul 2010, 10:20 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 01:18 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 10:37 -
VirtualDub-MPEG Warning Improper Join?
By geewhiz in forum DVD RippingReplies: 2Last Post: 23rd Jun 2007, 07:10
