Hi
Is there a program that will let me join wavs in one shot ??
I have 26 wavs i want to join into one large wav file.
I'm looking for something like "merge & Cut" in TMPGEnc Plus 2.5
Except for wav files, where i can load all 26 at the same time and have the output be a single file. I have other programs but you have to do one at a time and it is very time consuming.
Try
Goldwave,
WinOnCD,
CoolEditPro
They may not work exactly as "merge & cut" in TMPGenc, but I know you can drag and drop wav files into one long wav file and save it. I've never done 26 at a time, but I'd imagine you could join as many as you want.
There may be other audio editing programmes that would work in the tools area. -
Hi
Thanks, actually if there are any in the tools section they don't specify that option. i looked through them all before posting but i found something called "Addawav" so i'm going to try it.
Thanks -
Addawav will definitely work - really simple and crazy fast.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Joining multiple .mkv files?
By Charmer in forum Video ConversionReplies: 6Last Post: 24th May 2010, 21:52 -
Joining Multiple AVI files...
By phorkster in forum EditingReplies: 4Last Post: 13th May 2010, 15:43 -
Joining multiple FLV files into one?
By Super Warrior in forum EditingReplies: 2Last Post: 30th Jan 2009, 22:42 -
Help joining wav and wmv files with Avisynth
By jjones3535a in forum EditingReplies: 2Last Post: 7th Jan 2009, 17:09 -
Joining multiple files
By transco in forum ffmpegX general discussionReplies: 2Last Post: 20th May 2007, 00:28
