Hello,
Ok I'll check it out this weekend. ThanksOriginally Posted by capmaster
Kevin
(PS I'm only a noob to the new RAM, I was using PC100 on my old HP so it's jumped quite a bit since the last time I looked at ram).
Kevin
Results 61 to 90 of 104
Hello,
Northcat - I looked at a computer store website but they didn't have 133mhz PC3200 RAM!
How can I be running pc3200 ram if I can't buy it????
I was capping a video tape on my wintv pvr250 at the time. Would that effect the reading at all?????
"looked a computer store"
sad...very sad....
http://www.overclockers.com/articles740/index02.asp
this can explain it better than I can, I'm not familiar enough to explain it without having the BIOS in front of me.
Also ask Cobra, he has a OC guide. -
Hello,Originally Posted by northcat_8
Thanks norhtcat. I'll have some reading for this weekend.
I'll probably want to upgrade to 1gig of ram after I get a new 3d card
Just another suggestion for major speed enhancement in addition to the 1 GB or more of RAM.
Get another HD, a 20 GB or something, put it on a different IDE channel than your OS drive and put your Page file on it and take your page file off of your OS drive and off of your Primary IDE channel.
For example, my setup is:
Primary IDE -
Master - 60 GB OS Drive (no page file)
Slave - 120 GB Capture Drive
Secondary IDE -
Master - 160 GB Finishing Drive (Page File = 2.5 x amount of RAM)
Slave - DVD Burner
See I capture to the 120, I edit and then encode and output to the 160. Then when I go to make the final video, I put it all together and output the final project back on the 120 drive. Then when I use TMPGenc DVD Author or whatever, I have it write the ISO to the 60 or 120 drive so when I burn it, I'm not reading and writing over the same IDE channel.
I just try to keep heavy data transaction going between the IDE channels, I try to never read and write heavy data from one drive to another drive on the same channe.
Just a suggestion. -
Thanks for the tip.
Though I'm spending so much on this computer I may wait a little bit before buying the ram and any additional storage space.
80gb is enough for me right now. And I'm quite happy with the speed for now.
It'll probably be after the holidays when I look for more ram. I just wanted to know what type to look for.
As I said I'll have some reading to do for this weekend.
I also went to www.blackviper.com and killed off all the unneeded services that XP thinks it needs.
Microsoft
those fuckers
I also do not have system restore enabled or any of that BS. -
Hello,
Ohh.... I get it now.Originally Posted by overclockers.com
So when I go looking for more ram in a month or so maybe I should look for PC 3200 at 533mhz right????
PC3200 = 400MHz. Since your chip runs at 533FSB all you really need (unless you're planning on overclocking) is PC2100 (266MHz). It believe that we seem to be getting memory speed mixed up with FSB. A chip with 400MHz FSB doesn't require 400MHz (PC3200) memory, it only requires 200MHz (PC1600) memory.
Hello,Originally Posted by ViRaL1
Ok thanks. I'll try to keep that in mind
I had a 366Mhz celeron E-machine for awhile and it was a good little machine.Originally Posted by Dr.Gee
They are not that bad. :P -
Not really. Just depends what you want to do with it!Originally Posted by Dr.Gee
I built a pc for our security cameras with a Celeron.
Then decided to do some video work with it. Worked great.
It won't run circles around my P4 machines but
the price was right!
Building another one with a Celeron D. Saved bucks again.
For heavy video work the P4 probably shines, but to say Celeron
sux is like saying the '71 Pinto wasn't a nice car.
Well, maybe that's a bad example!!!
_________________ -
If it is the only car you have, then you do not knock it. :POriginally Posted by Goober57
Don't have to knock it. The engine did that!!! 8)Originally Posted by bazooka
________________ -
My mother had a '71 Chevy Vega. They weren't much better than the Pinto. Needed the engine replaced because the alum. block 4 had a crap design and warped. The replacement ate its own timing belts.
And having the air conditioner running with that 2-speed automatic transmission was an exercise in frustration when trying to get up to traffic speed
But ...the Pinto was worse
Cosworth Vega! That was a screamin' machine.Originally Posted by Capmaster
0-60 in three days........or until the doors fell off (like my Rambler
Just kidding Cosworth owners!!!
_________________ -
My mother had a Rambler tooOriginally Posted by Goober57
A 1960 Rambler American
They were KHz in those daysOriginally Posted by ViRaL1
Hello,
THREADJACKERS!!!
Kevin
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
What? Three pages about a Celeron isn't enough for you?!?!?Originally Posted by yoda313
Just about every conceivable thing that could be said about your new toy has already been said, Yoda. Too much, in fact.
So ...let the thread evolve into its normal OT state ...hopelessly jacked
Hello,
Do I have a choice???Originally Posted by capmaster
I'll still revive this to it's ORIGINAL purpose if issues come up with installation or just bragging rights in the future
Hello,Originally Posted by tekkieman
What about the "Components" hmm????
Dvd burners, 3d cards, dsl... Those are independent of the processor. But I needed a new platform to work from. The old Amd 850mhz HP just wasn't cutting it.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Upgrade Celeron 2.6 socket 478 & mobo
By kenmo in forum ComputerReplies: 2Last Post: 6th Jul 2010, 22:29 -
How is it you can still buy dual core pcs at bestbuy?
By yoda313 in forum ComputerReplies: 26Last Post: 1st Jul 2010, 18:06 -
Best Netbook available at BestBuy
By ryangarfield in forum ComputerReplies: 6Last Post: 1st Jun 2010, 23:34 -
Memorex 2.4x DVD+R DL 50pack $19.99 at BestBuy
By dmagic1 in forum MediaReplies: 4Last Post: 3rd Oct 2007, 22:00 -
AMD Sempron Vs Celeron-M?
By Super Warrior in forum ComputerReplies: 8Last Post: 14th Sep 2007, 23:08
I wouldnt be braggin bout it
