I captured 3 old VHS tapes at 352x240, 29.97FPS; I burned to DVD as I captured, and fit about 6 hours on one DVD+RW.
Then, using DVD Decrypter, I ripped the 3 .VOB back to hard disk. I edited them using MPG Video Wizard and exported them back to .MPG at same size and frame rate (so no re-encoding, just cut out some unwanted footage).
Now I'm trying to use Roxio DVD Builder (part of Easy CD and DVD Creator 6 suite) to put these 3 movies back onto a single DVD+R and it's telling me they won't fit. But they all came from one disc so I know they will.
Did DVD Decrypter do something when it ripped, or is this a limitation of Roxio DVD Builder, or is there something inherent about all of this ripping and re-encoding?
sounds like Roxio's trying to re-encode. I'd use TMPGEnc DVD Author (30 day free trial) to load the VOBs using the Add Video button, and it should all go smooth.
EDIT:
BTW, a more appropriate subject that describes your problem might go a long way towards getting better answers
If in doubt, Google it. -
Jim,
Thanks for the advice - I'll try it.
As for the subject line, I'm blaming the forum software - I crafted a descriptive subject line but it was truncated.
What name put
By Sousa_Software in forum Blu-ray RippingReplies: 2Last Post: 1st Sep 2011, 19:37 -
how to put 5.1 surrouding audio on a CD-R?
By ayyak in forum AudioReplies: 13Last Post: 21st May 2009, 08:22 -
How do I put pictures on dvd?
By jbitakis in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2008, 19:27 -
how many xvid can i put on 1 dvd
By peterg60 in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 05:56 -
Which Interleave value should i put???
By X_Splinter in forum AudioReplies: 5Last Post: 17th Dec 2007, 11:58
