I just bought a Pioneer 108 and I put it in a Bytecc usb external enclosure.
Does the 108 need to be set to master or slave?![]()
Results 1 to 10 of 10
I keep getting this failed burn message after about 2 minutes on the burn.
This is whether I have the drive set to master or slave. Could this be a media problem?
7:02:06 AM #16 Text 0 File Cdrdrv.cpp, Line 1284
07:02:06.219 - PIONEER DVD-RW DVR-108\H3 T0 : Queue again later
7:02:06 AM #17 SCSI -500 File Cdrdrv.cpp, Line 1432
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x0AAC0000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
7:02:06 AM #18 CDR -500 File Writer.cpp, Line 311
SCSI command aborted
7:02:06 AM #19 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
7:02:06 AM #20 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
7:02:18 AM #21 Phase 127 File dlgbrnst.cpp, Line 1853
Generating DVD high compatibility borders
7:04:12 AM #22 Text 0 File dlgbrnst.cpp, Line 1711
Set remaining time: 0:00,000 (0ms) -> OK
7:04:12 AM #23 Phase 129 File dlgbrnst.cpp, Line 1853
Generating DVD borders completed successfully
7:04:12 AM #24 Text 0 File dlgbrnst.cpp, Line 1711
7:04:12 AM #25 Phase 38 File dlgbrnst.cpp, Line 1853
Burn process failed at 4x (5,540 KB/s) -
It's probably media related.
Try your existing brand at a lower write speed, and also try another brand.
After that the drive and USB enclosure and the USB connection itself need to be checked. -
Do you have USB2? I also seem to recall some BIOSs that need to have Hi-Speed turned on. You might check that.
Still a few bugs in the system... -
Yes I do have usb 2.0.. I think I have narowed it down to the media. I can
write to arita 4x dvd+r and ridata 4x dvd+rw. It just won't write to the prodisc 8x dvd+r. My sony dru-500, and nec-3500 both write to the prodisc just fine. I just thought that the pioneer 108 would be more versitile than that. I'm going to try some ritek 8x dvd-r's and see what happens. Maybe the 108 writes to - better. Thanks for the replies. -
Finally figured it out. It was a media problem. I got some memorex dvd-r
8x at bestbuy for $19.99 a fifty pack(got a couple
that happen to be ritek go5. Burned a couple of backup's @ 12x, problem solved!
I'd start a new topic, but this title is perfect.
I'm having trouble utilizing a LITEON ldw-411s in a ACS USB2.0 external case.
I've installed the drive in the case, jumper is set to master. None of my USB 2.0 equipped machines will recognize this setup (all my pc's would recognize the USB when I had a 250gb maxtor in there).
Is it a situation with the LITEON???
TIA"If Wal-Mart keeps slashing prices, how come nothing is free yet??" -
USB has more compatibility issues with DVD burners compared to FIREWIRE. I'd suggest using a FIREWIRE enclosure with your LITEON drive. Check out the LITEON FORUM at Cdfreaks.com they may have more info. regarding your question.Originally Posted by fhlh
External HDD Enclosure Question
By Timex in forum ComputerReplies: 4Last Post: 1st Aug 2011, 13:53 -
External Harddrive Enclosure
By AuroEdge in forum ComputerReplies: 0Last Post: 3rd Jan 2010, 12:20 -
This External hdd enclosure only confuses the sata vs eSata issue for me
By gll99 in forum ComputerReplies: 13Last Post: 12th Mar 2009, 21:01 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 19:45 -
Have they created an external enclosure for pci cards?
By yoda313 in forum ComputerReplies: 13Last Post: 21st Aug 2008, 22:58
