Hi,
I've capped a live video stream (with CocSoft StreamDown) to my HD in ASF format.
The file plays correcly in Winows Media Player. But now I'd like to open it in virtualdub through avisynth.
So I use the following script:
When I try to open it in virtualdub, I get the following error message:Code:directshowsource("c:\temp\reflector38142.asf")
How can I open it, or does it existe some toll which can open such asf files ?
Virtualdub can't open ASF files due to a legal threat from Micro$oft. Use ASF Tools to convert it to an AVI.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Virtualdub can work with asf/wmv files if they are processed by avisynth.
The only problem is that this file has no duration because I was capped from a live broadcast and not from a file stored on a server.
ASF Tools is unstable and crash (it has never worked for me). -
I've tried with fps=25 but always the same error message about the duration of the video.
you need to find virtualdub 1.3c. it will convert asf files.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 13:11 -
Codec problem in ASF/wmv file (wvc1)
By ezzeee1 in forum EditingReplies: 7Last Post: 25th Feb 2011, 20:16 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:56 -
help on .asf file conversion
By fabpozzi in forum Video ConversionReplies: 5Last Post: 23rd Jun 2008, 19:13 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 08:47
