ok i have an mpeg1 movie. The volume is so low. I have to turn it way up to even hear dialogs. The only thing is i also hear that annoying background fuzzy sound, like the one that you hear when volume is blasted but nothing is playing.
1.How do i extract the audio from the mpeg?
2.What program can i use to make the volume alot higher?
Open the mpeg1 video in goldwave.
Increase the audio with some filter, like maximize https://www.videohelp.com/forum/userguides/160649.php
Save as wav
Convert the wav to mp2 with 44100 audio and 224 kbit using for example ffmpeggui.
Multiplex the video and the new mp2 audio with tmpgenc under tools->simple multiplex.
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Try to edit my mpeg but no sound!
By leegundo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Aug 2010, 10:56 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 17:49
