I am trying to extract small part of music from a dvd movie but there is speech at the same time. can i extract only music to wav or mp3 ?
Thank you
Most likely not, if the speech and music isn't on separate audio tracks. There's a utility called Vocal remover that supposedly removes lyrics from music, leaving the instrumental part alone, but I've never tried it myself. Might work to remove speech from background music too.
/Mats -
If the audio is encoded as 5-channel, and the music and dialog are on separate channels, you might be able to, but more than likely they are mixed into the same channel, and you can't separate them.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Actually, I tried the vocal remover out of curiosity, and, depending on how the vocals is located over the channels, it works surprisingly well! I can see a new Karaoke business opportunity
/Mats -
ok guys i was able so far to extract audio from dvd but still can not seperate the tracks as i could not find any tool yet. I tried vocal remover but it does not seperate completely. I need a way to have the music only, any tool free or not i will get it.
Many thanks -
Completely or not depends on source material. I've noticed from "almost 100%" on some, to "not at all" for others.
I'm afraid that's how well it can be done, no matter how much you spend on the task. Only option as I see it, is to get the raw unmixed audio recordings from the producers...
/Mats
1080i 29.97 frames/sec to DVD compliant SD using Avisynth and HC encoder
By johnnyquid in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 16:24 -
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2011, 00:01 -
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38 -
How to extract music only?
By UncleBose in forum AudioReplies: 11Last Post: 14th Nov 2009, 09:51 -
Extract special CD-music to harddrive
By Blå_Mocka in forum AudioReplies: 3Last Post: 21st Jul 2007, 07:51
