Hey, there. I downloaded a DVD image of a PAL movie with AC3 audio. That seems to be the only audio on the image. Anyway, I finally figured out how to convert from PAL to NTSC. I used NeoDVDPlus to do so. The resulting DVD plays in my DVD player, but I get no audio. I realized after that the audio is in AC3. Do all DVD players support AC3? In other words, I'm trying to figure out if there is no audio because my DVD player can't support that format or if it's because NeoDVDPlus doesn't know how to handle an AC3 stream. In either case, what do I do? Do I need to change the audio to a different format? I'm something of a novice, so any help would be appreciated. Thanks.
Take a look at your NTSC version of the DVD and see if it contains any audio at all - if not, NeoDVDPlus is the culprit.
/Mats
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 05:32 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
