Question on the TEPGEN 3.0 program... anyone have problems getting the "fade in out" audo plugin to work? I have the audio plugin enabled, but, I can't any audio fade effects when I try on clips..![]()
Ideas![]()
what on earth is
even google doesn´t know thisTEPGEN 3.0 program
maybe you should check the name
bye Daphy -
maybe you should update to their latest version, I´ve read they fixed something depending to your problem
How to install SimplyBurns a basic and simple burn-ware?
By Bonie81 in forum MacReplies: 3Last Post: 7th Jan 2012, 19:14 -
Vm Ware+Xp+USb:problem
By themaster1 in forum ComputerReplies: 3Last Post: 4th Jul 2008, 19:28 -
best hardware + s'ware for bulk vhs to file capture & archiving
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 8th Sep 2007, 21:05
I didnt mean to go over your heads there. Anyway, ________ =
