It is a 50 pack.... Wondering if the Taiwan is any good? Not sure I havent checked, but will go tomorrow to check on. Because my friend got a 25 pack of Verbatim Movie Reel 4x and had the media code of MCC. And had no problems. The Movie Reel were " Made in Taiwan". I thought MCC was 1st class and very good. But MCC Media ID on Taiwan made?
Results 1 to 13 of 13
"What It Do"
Huh ????? -
Most Verbatim/Mitsubishi media is made in Taiwan by either Prodisc or CMC these days. Frankly I've had better success with the 8x +R spindles than the 8x -R ones.
Originally Posted by Gen-An
So if it comes out with MCC Media ID , then it isnt any good? Why doesnt it says then CMC or Prodisc???"What It Do"
Huh ????? -
Mitsubishi uses Prodisc and CMC to manufacture its own discs, but when doing so they use the Mitsubishi dye and stampers. So just think of them as MCC made by CMC or MCC made by Prodisc.
What does that mean in terms of quality? Are "MCC Made by CMC" usually better then those discs with CMC media ID's? Or the same as "real" CMC?Originally Posted by Gen-An
(i've had problems with discs with CMC media id's so I want to avoid that again if possible.) -
the quality should be the same, but who knows.
anyway, there is no option, right ? I preffer Maxell and Sony, made by Ricoh -
You can get Prodiscs from Rima for that price, I have never had any problems with them, used hundreds.
MCC made by CMC is better than regular CMC. However the MCC made in Singapore at the MCC plant are better than those made in Taiwan by Prodisc or CMC (but those are very hard to find these days).
Let's keep it simple: MCC is good media. Period.
In the early days, Mitsubishi had Singapore plants that made MCC. They then moved the operation to Taiwan. Same materials, etc. Still good. Prodisc now has MCC media too, but the exact details on it are not that widely known (materials, stampers, etc). At any rate, it's still sold as "Prodisc" to date. Prodisc is still decent media.Want my help? Ask here! (not via PM!)
Well technically MCC is still producing media at the Singapore plant (mostly Dual Layer I believe) and there is MCC made by Prodisc sold under the Verbatim/Mitsubishi labels (I have a spindle of DigitalMovie +Rs that were made by Prodisc).
I was under the impression all DVD5 write-once was cleared out, and they're now just making rewritable and next-gen media (DL).
Some MCC004 (16x) made in Singapore has shown up in the European packaging.
How easily I forget 16x.
Sony Micro MV camera?
By lordsmurf in forum Capturing and VCRReplies: 2Last Post: 21st Mar 2010, 19:38 -
Can't get Norwood Micro dvd r-w to function
By Raptorcat61 in forum DVD & Blu-ray WritersReplies: 6Last Post: 21st Feb 2008, 10:43 -
MAY BE OLD NEWS Micro Center has 20pk Verbatim DVD+R DL $27.99 thru 6/17
By louv68 in forum MediaReplies: 1Last Post: 12th Jun 2007, 13:39 -
Micro Center or Gamestop to Trade in old video game systems?
By RKelly in forum Off topicReplies: 6Last Post: 24th May 2007, 15:45 -
1GB DDR2 667/533 DIMM $39.99 at Micro Center Worth it?
By louv68 in forum ComputerReplies: 5Last Post: 10th May 2007, 12:54
