  1. I'm having trouble making a dvd cover in PhotoShop 8. I made it 10.75 inches x 7.25 inches at 72 pixels/inch using landscape page setup. When I try to print it says "The image is larger than the page's printable area; some clipping will occur". Anyone know why this is happening?
  2. Member Umbearto's Avatar
    Jan 2004
    Calgary
    Umm... 10.75 inches that leaves a left and right margin of 1/8th inch; What are the minimum margins of your printer..?
    (You might want to increase your resolution as 72dpi pretty low for printing)
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I use 10.6 x 7.25 @ 200 dpi for a standard DVD case cover. You may want to click Print with preview and adjust the offset lines.
    Here's my standard DVD template if anyone want's to use it:
    It's a transparent png. Make sure you save it as a png.
