something i found on the web
http://sch-yuri.narod.ru/DVD/the_cce_2.htm
loads slowly ...
If I remember correctly........back when I was playing around with CCE, v2.50 seemed to outperform v2.67 on 1-pass encodes. I think @ 3-pass and higher, it was harder to tell them apart.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I found that site about a fortnight back after looking for some CCE tweeks, as opposed to the usual <boring> Doom9 guides (much copied everywhere).
Wether or not they are true comparisons (eg. how come 2.5 uses 20 image priority and 2.64 only 12?) is debateable.
The problem with CCE and many other encoders is that there is (to be blunt)..... TO BLOODY MANY variables to make any serious judgements/comparisons.
Ignoring input resolutions/scaling/scripts/filters/etc and bitrates there is still probably over 20,000 possible permitations..(throw bitrates etc into the mix and it must be in the MULTI millions).
From a software point of view arent point releases (ie 2.5 or 2.64) regarded as MINOR changes in the software (debugging, interfaces, minor softeware tweeks etc) as opposed to partial or full re-writing of whole interger releases? Only way to tell if that site is telling the truth is to do it yourself. -
MONZIE - you are right ....
but as for CCE and release numbers -- they don't always make a lot of sense .. versions above 2.5 were all about the same up to 2.69 ... 2.7 is a lot different ..
official cce retails releases also bear this out as they really only had one release between 2.5 and 2.7 , not the 6 different versions you see floating about (but they did have available for download as trial)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Versions after 2.5 use a larger scale for image quality priorty. I think 2.5 is 0-60 and after that its 0-100.Originally Posted by monzie
I've tried later versions and still prefer 2.5 personally. -
Using 2.5 and 2.62 (on seperate pc's) and to be honest I cant tell any difference (on TV) using same settings.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 21:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 13:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 15:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
